What's New in ArcXML 1.1 for ArcIMS 4.0 |
ArcXML 1.1 has several new elements and attributes. The new or changed features are described below. New elements were added to support the Metadata and ArcMap Servers. In addition, some elements were added for supporting some new functionality with raster images.
Several documents have been added to the ArcXML 1.1 introductory section that provide comprehensive explanations and additional examples on the ArcMap Server:
The following elements have been added to support the Metadata Server. For more information on using the Metadata Server, see Creating and Using Metadata Services.
These elements are used to publish metadata documents to the Metadata Server.
These elements are used to browse metadata documents that have been published to the Metadata Server.
These elements are used in metadata configuration files.
The following elements have been added to support the ArcMap Server. Additional information on using the ArcMap Server elements can be found in the introductory section of this guide.
The following elements have new attributes to support the ArcMap Server.
The following elements can be used in map configuration files to classify image pixel values.
The following element can be used to turn off image generalization.
The following elements can be used to identify the value of a pixel in an Image or ArcMap Image Service.
The following elements have new attributes. Only the new attributes are listed here:
The following element has new child elements. Only the new elements are listed here:
The following elements have been deprecated in ArcIMS 4.0. You can still use them, but ArcIMS 4.0 is the last version they will be supported.
