| RASTER_RANGE | Examples |
| <RASTER_RANGE | Attribute
Description Table |
| lower ="double" upper ="double" color ="0,0,0 - 255,255,255" [0,0,0] equality ="all | upper | lower | none" [lower] label ="string" [Value of lower or upper] transparency ="0.0 - 1.0" [1.0] > No Child Elements </RASTER_RANGE > | |
| Bold: Attribute or child element is
required. | |
| Attribute | Usage | Back to Top |
| color | Color using RGB values. Defines the color corresponding to the specified range of index values. | |
| equality | Defines the upper and lower bounds of each range. If "all" is used, then lower <= value <= upper. If "upper" is used, lower < value <= upper. If "lower" is used, lower <= value < upper. | |
| label | Description to be shown on legend. Valid with HTML Viewers only. | |
| lower | Defines the lower value of the range. | |
| transparency | Value to set percentage of transparency. 1.0 is 0 percent transparent. 0.0 is 100 percent transparent. | |
| upper | Defines the upper value of the range. | |
| Example 1: When in a map configuration file. | Back to Top |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT> <LOCALE country="US" language="en" variant="" /> <UIFONT color="0,0,0" name="Arial" size="12" style="regular" /> </ENVIRONMENT> <MAP> <PROPERTIES> <ENVELOPE minx="-90" miny="-180" maxx="90" maxy="180" name="Initial_Extent" /> <MAPUNITS units="decimal_degrees" /> <FILTERCOORDSYS id="4326" /> <FEATURECOORDSYS id="4326"/> </PROPERTIES> <WORKSPACES> <SDEWORKSPACE name="sde_ws-0" server="myserver" instance="port:5151" database="" user="sdeuser" encrypted="true" password="LXEMUR" /> </WORKSPACES> <LAYER type="image" name="Land Use" visible="true" id="0"> <DATASET name="SDEUSER.BIT8_COLORMAP.RASTER" workspace="sde_ws-0" /> <RASTER_RENDERER> <RASTER_EXACT value="0" color="10,200,10" transparency="0.5" label="Clouds"/> <RASTER_RANGE lower="1" upper="101" color="200,40,10" transparency="0.5" equality="lower" label="Urban"/> <RASTER_RANGE transparency="1.0" lower="101" upper="255" color="255,255,10" equality="lower" label="Rural"/> <RASTER_OTHER transparency="0.0" label="Other"/> </RASTER_RENDERER> </LAYER> </MAP> </CONFIG> </ARCXML> | |
