| PUT_METADATA | Examples |
| <PUT_METADATA | Attribute
Description Table |
| docid ="string" name ="string" content ="liveData | downloadableData | offlineData | staticMapImage | document | application | geographicService | clearinghouse | mapFiles | geographicActivities | unknown" folder ="true | false" [false] onlink ="string" parentdocid ="string" private ="true | false" [false] server ="string" service ="string" servicetype ="metadata | image | feature | wms" > <ENVELOPE... /> <THUMBNAIL... /> </PUT_METADATA > | |
| Bold: Attribute or child element is
required. | |
| Attribute | Usage | Back to Top | ||||||||||||||||||
| content | The values for this attribute
correspond to the content types listed in the drop-down combo box of the
Metadata Explorer.
| docid | String used to uniquely identify a
document. The client used to publish the metadata is responsible for
creating the document ID. This ID is automatically assigned when using
ArcCatalog. If another client is used, GET_UUID can be used to
request a valid ID. The format for an ID is the
following: {HHHHHHHH-HHHH-HHHH-HHHH-HHHHHHHHHHHH} where H is a hexadecimal digit (0-9,a-f,A-F). The ID is limited to 38 characters. | |||||||||||||||||||
| folder | Determines whether document represents a folder. Use "false" if the document does not contain other documents. Use "true" if the document represents a folder. | |||||||||||||||||||
| name | Name that identifies the dataset corresponding to the document. | |||||||||||||||||||
| onlink | A string identifying the location of the dataset corresponding to the document. | |||||||||||||||||||
| parentdocid | Unique string for identifying a
document belonging to the parent name and parent owner. The client used to
publish the metadata is responsible for creating the document ID. This ID
is automatically assigned when using ArcCatalog. If another client is
to request a valid ID. The format for an ID is the
| private | Determines whether document is viewable for all users. Use "false" if the document is viewable by all users. Use "true" when the document is viewable only by the document owner. | |||||||||||||||||||
| server | The URL of the Web server containing data or metadata associated with the document, for example, http://mymachine.domain.com. | |||||||||||||||||||
| service | The name of the service containing data or metadata associated with the document. | |||||||||||||||||||
| servicetype | Type of ArcIMS service. | |||||||||||||||||||
| Example 1: | Back to Top |
| <?xml version="1.0"
encoding="UTF-8" ?> <ARCXML version="1.1"> <REQUEST> <PUBLISH_METADATA> <PUT_METADATA name="World" docid="{C64D8F38-82B4-11D5-99C2-000086460FA0}" private="false" folder="true" parentdocid="root" > <ENVELOPE minx="-180" miny="-90" maxx="180" maxy="90" /> <THUMBNAIL>...</THUMBNAIL> <!--<?xml version="1.0"?> <metadata>...</metadata>--> </PUT_METADATA> </PUBLISH_METADATA> </REQUEST> </ARCXML> | |
