| SEARCH_METADATA | Examples |
| <SEARCH_METADATA | Attribute
Description Table |
| foldermask ="1 - 15" maxresults ="integer" [All records matching search criteria] operator ="and | or" [and] sort ="name | relevance | contenttype | local_area | global_area" [name] sort2 ="name | relevance | contenttype | local_area | global_area" startresult ="integer" [0] > (m) <DOCUMENTINFO... /> [And/Or] (m) <ENVELOPE... /> [And/Or] (m) <FULLTEXT... /> [And/Or] (m) <SEARCH_METADATA... /> [And/Or] (m) <SUBSET... /> [And/Or] (m) <TAGTEXT... /> [And/Or] (m) <TAGVALUE... /> [And/Or] <UPDATED... /> [And/Or] </SEARCH_METADATA > | |
| Bold: Attribute or child element is
required. (m): Child element can be used multiple times. | |
| Attribute | Usage | Back to Top |
| foldermask | 1 Specifies folder types to be
returned in the response. The value of foldermask is an integer
storing the sum of one or more of the following values:
| maxresults | 2 By default, all records meeting the search criteria are returned. This attribute limits the number of returned records to the maximum value assigned to the attribute. | |
| operator | 3 Used to define the operator for the SEARCH_METADATA query. | |
| sort | 4 Preference for ordering results. "Name" orders the results alphabetically. "Relevance" lists results from highest to lowest relevance. "Contenttype" sorts and groups results by content type. "Local_area" lists results by area in ascending order. "Global_area" lists results by area in descending order. | |
| sort2 | 5 Sorts search results that were batched using startresult and maxresults. "Name" orders the results alphabetically. "Relevance" lists results from highest to lowest relevance. "Contenttype" sorts and groups results by content type. "Local_area" lists results by area in ascending order. "Global_area" lists results by area in descending order. | |
| startresult | 6 By default, all records meeting the search criteria are returned starting with record 0. This attribute allows a specified record as the start record. | |
| Example 1: When searching by name or owner of documents using DOCUMENTINFO. | Back to Top |
| <?xml version="1.0"
encoding="UTF-8" ?> <ARCXML version="1.1"> <REQUEST> <GET_METADATA> <SEARCH_METADATA> <DOCUMENTINFO name="World" /> </SEARCH_METADATA> </GET_METADATA> </REQUEST> </ARCXML> | |
| Example 2: When using SUBSET. | Back to Top |
| <?xml version="1.0"
encoding="UTF-8" ?> <ARCXML version="1.1"> <REQUEST> <GET_METADATA> <SEARCH_METADATA> <SUBSET type="children" docid="{F7DDF21-BC01-4C20-8AA5-243B33ED0B1E}" /> </SEARCH_METADATA> </GET_METADATA> </REQUEST> </ARCXML> | |
| Example 3: When using TAGVALUE. | Back to Top |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <REQUEST> <GET_METADATA> <SEARCH_METADATA operator="and" maxresults="10" startresult="0" > <TAGVALUE tag="metadata/idinfo/citation/citeinfo/pubdate" greaterthanorequalto="20001006" lessthanorequalto="20010104"/> </SEARCH_METADATA> </GET_METADATA> </REQUEST> </ARCXML> | |
| Example 4: When using ENVELOPE, TAGVALUE, FULLTEXT, and SEARCH_METADATA recursively with TAGTEXT. | Back to Top |
| <?xml version="1.0"
encoding="UTF-8" ?> <ARCXML version="1.1"> <REQUEST> <GET_METADATA> <SEARCH_METADATA operator="and"> <ENVELOPE minx="-176.98" miny="18.93" maxx="-66.97" maxy="71.35" spatialoperator="within" /> <TAGVALUE tag="metadata/dataqual/lineage/srcinfo/srccite/citeinfo/pubdate" greaterthan="1990" /> <FULLTEXT word="cities"/> <SEARCH_METADATA operator="or"> <TAGTEXT tag="metadata/idinfo/citation/citeinfo/geoform" word="data"/> <TAGTEXT tag="metadata/idinfo/citation/citeinfo/geoform" word="digital"/> </SEARCH_METADATA> </SEARCH_METADATA> </GET_METADATA> </REQUEST> </ARCXML> | |
