| ADMIN_TABLE | Examples |
| <ADMIN_TABLE | Attribute
Description Table |
| idcolumn ="string" insert ="string" tablename ="string" filter ="string" > (m) <RESPONSE_COLUMN... /> </ADMIN_TABLE > | |
| Bold: Attribute or child element is
required. (m): Child element can be used multiple times. | |
| Attribute | Usage | Back to Top |
| filter | 1 SQL where clause to execute against the ADMIN_TABLE. The clause is appended with an AND to every where clause generated by SEARCH_METADATA. | |
| idcolumn | 2 Name of field in the ADMIN_TABLE containing the join time ussed to join the administration table to the main internal metadata table. The ID column in the ADMIN_TABLE must be a string field 38 characters in length. | |
| insert | 3 SQL INSERT statement to execute
against the ADMIN_TABLE whenever a new document is added to the Metatdata
Server. Must contain '%s' (including the single quotes) in place of the ID
field value. The value '%s' is a placeholder for the internal ID and is
assigned automatically by the Metadata Server. The ID field must be a
string field 38 characters in length. In the following example, the ADMIN_TABLE has two columns: the first is "docUUID", and the second is "service_running". The column "docUUID" is the field used to relate the ADMIN_TABLE to the main internal metadata table. INSERT into <ADMIN_TABLE> (docUUID, service_running) values ('%s','No'). | |
| tablename | 4 Name of external ADMIN_TABLE for administrator's use. | |
| Example 1: | Back to Top |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT> <LOCALE country="US" language="en" variant="" /> <UIFONT color="0,0,0" name="Arial" size="12" style="regular" /> </ENVIRONMENT> <METADATA_CONFIG> <WORKSPACES> <SDEWORKSPACE name="unique_name" server="server_name" instance="port:5151" database="optional_database_name" user="user_name" password="user_password" /> </WORKSPACES> <ADMIN_TABLE tablename="AdminTable" idcolumn="DocUUID" filter="Approved='Y'" insert="INSERT INTO AdminTable (DocUUID, Approved) VALUES ('%s', 'N')"> <RESPONSE_COLUMN columnname="Approved" /> </ADMIN_TABLE> <METADATA_CONTENT validate="true" /> <TABLE_NAME prefix="imsmetadata" /> </METADATA_CONFIG> </CONFIG> </ARCXML> | |
