What's New in ArcXML 1.1 for ArcIMS 4.0.1 |
The following changes have been made to ArcXML 1.1 since the release of ArcIMS 4.0. ArcXML 1.1 has several new elements and attributes. The new or changed features are described below.
The following elements have been added to support the Metadata Server. For more information on using the Metadata Server, see Creating and Using Metadata Services.
The following elements have new attributes.
The following elements have attributes with new values.
The following elements have attributes values that were removed.
The following element has been moved and has a new parent element.
The following elements have changes. Additional information on using the ArcMap Server elements can be found in the introductory section of this guide.
The following elements have updates:
You can choose whether to include raster pixel values in the legend when a colormap or RASTER_RENDERER is used. The following element has new attributes.
The following elements have new attributes to support image streaming. Image streaming is supported with Image Services only and has been implemented in the Java Connector. No other connectors support this functionality.
The following elements were added to the ArcXML documentation for convenience. These elements are not new and were previously documented in the ArcIMS Help. You can use these elements along with SERVICES and SERVICE to manage and ArcIMS site from the command line.
