| GET_SERVICE_INFO | Examples |
| <GET_SERVICE_INFO | Attribute
Description Table |
| dpi ="1 - NNN" envelope ="true | false" [true] extensions ="true | false" [true] fields ="true | false" [true] renderer ="true | false" [true] > No child elements </GET_SERVICE_INFO > |
| Attribute | Usage | Back to Top |
| dpi | Dots per inch (dpi). Used for calculating the correct scale thresholds for scale dependent elements such as SCALEDEPENDENTRENDERER, LAYER, and OBJECT. The dpi value used in request overrides the value used in a MapService. | |
| envelope | Toggle to get information on the envelope for featureclass layers in a MapService. Featureclass layers include shapefile and ArcSDE layers. | |
| extensions | Toggle to get information on any MapService extensions in featureclass layers. | |
| fields | Toggle to get information on available fields for each featureclass layer in the MapService. | |
| renderer | Toggle to get renderer information for featureclass layers in a MapService. | |
| Example 1: | Back to Top |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <REQUEST> <GET_SERVICE_INFO fields="false" envelope="false" renderer="false" extensions="true" /> </REQUEST> </ARCXML> |
