| GET_IMAGE | Examples |
| <GET_IMAGE | Attribute
Description Table |
| autoresize ="true | false" [false]
show ="layers" [layers] > <PROPERTIES... /> <ENVIRONMENT... /> (m) <LAYER... /> <WORKSPACES... /> </GET_IMAGE > | |
| Bold: Attribute or child element is
required. (m): Child element can be used multiple times. | |
| Attribute | Usage | Back to Top |
| autoresize | The maximum image generated size is based on the image memory limit set when an Image MapService is started. For example, an image memory limit of 1 MB allows a map no larger than 262,144 pixels (512 x 512) to be generated. If autoresize is set to "true", a requested map greater than the maximum pixel count will be reduced in size to within the maximum pixel count. If autoresize is set to "false", no image is generated and an error message is returned by the ArcIMS Spatial Server. | |
| show | Use this attribute to return layer information in the response including layer ID, name, and number of features in the map. | |
| Example 1: Example using projections, queries, selected features, and acetate layers. The IMAGE response includes layer information since the attribute "show" is used. | Back to Top |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <REQUEST> <GET_IMAGE show="layers"> <PROPERTIES> <ENVELOPE minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0" /> <IMAGESIZE width="800" height="600" /> <FEATURECOORDSYS id="54030" /> <FILTERCOORDSYS id="4326" /> <LAYERLIST> <LAYERDEF id="0" visible="true" /> <LAYERDEF id="1" visible="true" /> <LAYERDEF id="2" visible="false" /> <LAYERDEF id="3" visible="false" /> <LAYERDEF id="4" visible="true" > <SPATIALQUERY where="POPULATION > 2000000" > <SPATIALFILTER relation="area_intersection"> <ENVELOPE minx="-14.0" miny="35.0" maxx="33.0" maxy="64.0" /> </SPATIALFILTER> </SPATIALQUERY> <SIMPLERENDERER> <SIMPLEMARKERSYMBOL type="star" color="0,155,0" width="12.0" /> </SIMPLERENDERER> </LAYERDEF> </LAYERLIST> </PROPERTIES> <LAYER type="featureclass" name="new_CNTRY94" id="333" > <DATASET fromlayer="1" /> <SPATIALQUERY where="NAME='Brazil'" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL filltype="solid" fillcolor="255,0,0" /> </SIMPLERENDERER> </LAYER> <LAYER type="acetate" name="WorldText" id="444" > <OBJECT units="pixel"> <TEXT size="32" coords="100 44" label="The World"> <TEXTMARKERSYMBOL fontstyle="bold" fontsize="32" font="Arial" fontcolor="0,0,0" glowing="255,255,0" /> </TEXT> </OBJECT> </LAYER> <LAYER type="acetate" name="WorldBox" id="3333"> <OBJECT units="pixel"> <LINE coords="10 40;400 40;400 80;10 80;10 40"> <SIMPLELINESYMBOL color="0,0,0" /> </LINE> </OBJECT> </LAYER> </GET_IMAGE> </REQUEST> </ARCXML> | |
| Example 2: | Back to Top |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <REQUEST> <GET_IMAGE> <PROPERTIES> <LAYERLIST> <LAYERDEF id="1"> <SIMPLERENDERER> <SIMPLEMARKERSYMBOL size="16" color="0,0,0" /> </SIMPLERENDERER> <SPATIALQUERY> <SPATIALFILTER relation="area_intersection"> <ENVELOPE maxy="60" maxx="60" miny="0" minx="0" /> </SPATIALFILTER> </SPATIALQUERY> </LAYERDEF> </LAYERLIST> <ENVELOPE minx="-180" miny="-90" maxx="180" maxy="90" /> </PROPERTIES> </GET_IMAGE> </REQUEST> </ARCXML> | |
