| Using Map and Viewer Configuration Files |
| Tool | File Format | File Extension | Valid ArcIMS Services |
| Author | ArcXML file | *.axl | Feature and Image Services |
| XML Editor | ArcXML file | *.axl | Feature and Image Services |
| ArcMap | ArcMap map file | *.mxd | ArcMap Image Services |
| ArcMap | Published map file | *.pmf | ArcMap Image Services |
| Framework of a map configuration file: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT>...</ENVIRONMENT> <MAP> <PROPERTIES>...</PROPERTIES> <WORKSPACES>...</WORKSPACES> <LAYER>...</LAYER> </MAP> </CONFIG> </ARCXML> |
| Prolog and ARCXML: |
| <?xml
version="1.0" encoding="UTF-8"?> <ARCXML version="1.1"> ... </ARCXML> |
| CONFIG, ENVIRONMENT, and MAP: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT>...</ENVIRONMENT> <MAP>...</MAP> </CONFIG> </ARCXML> |
| ENVIRONMENT and its child elements: |
| <ENVIRONMENT> <LOCALE language="en" country="US" /> <UIFONT name="Arial" color="0,0,0" size="12" style="regular" /> <SEPARATORS cs=" " ts=";"/> <SCREEN dpi="96"/> </ENVIRONMENT> |
| MAP and its child elements: |
| <MAP> <PROPERTIES>...</PROPERTIES> <WORKSPACES>...</WORKSPACES> <LAYER>...</LAYER> </MAP> |
| PROPERTIES and its child elements for both Feature and Image Services: |
| <PROPERTIES> <ENVELOPE minx="-105.594842" miny="-49.955227" maxx="75.672764" maxy="83.596039" name="Initial_Extent" /> <MAPUNITS units="decimal_degrees" /> <FEATURECOORDSYS id="54008" /> <FILTERCOORDSYS id="54008" /> </PROPERTIES> |
| Using ENVELOPE: |
| <PROPERTIES> <ENVELOPE minx="-61.1" miny="3.7" maxx="91.7" maxy="61.3" name="Initial_Extent" reaspect="true" /> ... <PROPERTIES> |
| Reaspect
set to true |
Reaspect
set to false |
| PROPERTIES and its child elements valid only with Image Services (in bold): |
| <PROPERTIES> <ENVELOPE minx="-105.594842" miny="-49.955227" maxx="75.672764" maxy="83.596039" name="Initial_Extent" /> <MAPUNITS units="decimal_degrees" /> <FEATURECOORDSYS id="54008" /> <FILTERCOORDSYS id="54008" /> <BACKGROUND... /> <LEGEND... /> <OUTPUT... /> </PROPERTIES> |
| Browser | Supported Transparent Image Formats |
| ArcIMS HTML Viewer in Internet Explorer | PNG8, GIF |
| ArcIMS HTML Viewer in Netscape 4.x | GIF |
| ArcIMS HTML Viewer in Netscape 6.x | PNG8, GIF |
| ArcExplorer 4 | PNG24, PNG8, GIF |
| ArcIMS Java Viewers in Internet Explorer and Netscape | PNG24, PNG8, GIF |
| Valid WORKSPACES in a map configuration file: |
| <WORKSPACES> <SHAPEWORKSPACE name="shp_ws-0" directory="c:\ESRIDATA"/> <IMAGEWORKSPACE name="jai_ws-1" directory="c:\ESRIDATA"/> <SDEWORKSPACE name="sde_ws-2" server="zephyr" instance="port:5150" database="" user="washoe" encrypted="true" password="LXEMUR" /> </WORKSPACES> |
| Sample LAYER with attributes: |
| <LAYER type="featureclass" name="CITIES" minscale="1:24000" maxscale="1:100000" visible="true" id="2"> ... </LAYER> |
| LAYER with child elements: |
visible="true" id="2"> <DATASET name="Cities_Robinson" type="polygon" workspace="shp_ws-0" /> <DENSIFY tolerance="10000" /> <COORDSYS id="54030" /> <SPATIALQUERY where="population > 1000000" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL filltransparency="1.0" fillcolor="27,127,127" /> </SIMPLERENDERER> </LAYER> |
| Valid symbols inside SIMPLERENDERER and VALUEMAPRENDERER are: |
| Valid symbols inside SIMPLELABELRENDERER and VALUEMAPLABELRENDERER are: |
| For more detailed information on the renderers, see Using Renderer Elements. |
| Example map configuration file: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT> <LOCALE country="US" language="en" variant="" /> <UIFONT color="0,0,0" name="Arial" size="12" style="regular" /> <SCREEN dpi="96" /> </ENVIRONMENT> <MAP> <PROPERTIES> <ENVELOPE minx="-135.0" miny="-64.0" maxx="84.0" maxy="86.0" name="Initial_Extent" /> <MAPUNITS units="decimal_degrees" /> </PROPERTIES> <WORKSPACES> <SHAPEWORKSPACE name="shp_ws-4" directory="<path to WORLD ESRIDATA>" /> </WORKSPACES> <LAYER type="featureclass" name="Oceans" visible="true" id="0"> <DATASET name="WORLD30" type="polygon" workspace="shp_ws-4" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL fillcolor="51,153,255"/> </SIMPLERENDERER> </LAYER> <LAYER type="featureclass" name="Countries" visible="true" id="1"> <DATASET name="country" type="polygon" workspace="shp_ws-4" /> <GROUPRENDERER> <VALUEMAPRENDERER lookupfield="POP_CNTRY"> <RANGE lower="0" upper="50000000" label="Less than 50000000"> <SIMPLEPOLYGONSYMBOL fillcolor="255,255,0"/> </RANGE> <RANGE lower="50000001" upper="100000000" label="50000000 - 100000000"> <SIMPLEPOLYGONSYMBOL fillcolor="255,170,0" /> </RANGE> <RANGE lower="100000001" upper="1281008319" label="Greater than 100000000"> <SIMPLEPOLYGONSYMBOL fillcolor="255,85,0"/> </RANGE> </VALUEMAPRENDERER> <SCALEDEPENDENTRENDERER upper="1:35000000"> <SIMPLELABELRENDERER field="CNTRY_NAME"> <TEXTSYMBOL antialiasing="true" font="Arial Bold" fontstyle="bold" fontsize="12" /> </SIMPLELABELRENDERER> </SCALEDEPENDENTRENDERER> </GROUPRENDERER> </LAYER> </MAP> </CONFIG> </ARCXML> |
| Change in initial ENVELOPE: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT>...</ENVIRONMENT> <MAP> <PROPERTIES> <ENVELOPE minx="-13.0" miny="36.0" maxx="34.0" maxy="69.0" name="Initial_Extent" /> <MAPUNITS units="decimal_degrees" /> </PROPERTIES> <WORKSPACES>...</WORKSPACES> <LAYER>...</LAYER> </MAP> </CONFIG> </ARCXML> |
| Example viewer configuration file: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT> <LOCALE country="US" language="en" variant="" /> <UIFONT color="0,0,0" name="Arial" size="12" style="regular" /> <SCREEN dpi="96" /> </ENVIRONMENT> <MAP> <PROPERTIES> <ENVELOPE minx="-178.0" miny="12.89" maxx="-68.0" maxy="83.59" name="Initial_Extent" /> <MAPUNITS units="decimal_degrees" /> </PROPERTIES> <WORKSPACES> <IMAGESERVERWORKSPACE name="mapper_ws-6" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" service="background" /> <FEATURESERVERWORKSPACE name="ifs_ws-7" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" service="states" /> <AVIMSWORKSPACE name="av_ws-6" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" view="Roads" map="roads21204240" /> <MOIMSWORKSPACE name="mo_ws-4" url="http://mymachine.domain.com/scripts/esrimap.dll" service="GPS_Points" /> <SHAPEWORKSPACE name="shp_ws-8" directory="<path to CANADA ESRIDATA" /> </WORKSPACES> <LAYER type="image" name="Background" visible="true" id="0"> <DATASET name="background" type="image" workspace="mapper_ws-6" /> </LAYER> <LAYER type="featureclass" name="States" visible="true" id="1"> <DATASET name="2" type="polygon" workspace="ifs_ws-7" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,255,153" boundarycaptype="round" /> </SIMPLERENDERER> </LAYER> <LAYER type="featureclass" name="Provinces" visible="true" id="2"> <DATASET name="province" type="polygon" workspace="shp_ws-8" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="127,27,27" boundarycaptype="round" /> </SIMPLERENDERER> </LAYER> <LAYER type="image" name="Roads" visible="true" id="3"> <DATASET name="mymachine.domain.com:roads21204240:Roads" type="image" workspace="av_ws-6" /> <IMAGEPROPERTIES transparency="0.80" /> </LAYER> <LAYER type="image" name="GPS Points" visible="true" id="4"> <DATASET name="mymachine.domain.com:GPS_Points" type="image" workspace="mo_ws-4" /> </LAYER> </MAP> <OVERVIEWMAP backgroundcolor="255,255,255" framefillcolor="255,0,0,80" frameoutlinecolor="255,0,0" zoomfactor="4.0"> <LAYERDEF name="States" /> <LAYERDEF name="Provinces" /> </OVERVIEWMAP> <SCALEBAR backcolor="212,208,200" fontcolor="0,0,0" mapunits="decimal_degrees" scaleunits="feet" screenunits="inches" /> </CONFIG> </ARCXML> |
| Using IMAGESERVERWORKSPACE: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT>...</ENVIRONMENT> <MAP> <PROPERTIES>...</PROPERTIES> <WORKSPACES> <IMAGESERVERWORKSPACE name="mapper_ws-6" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" service="background" /> </WORKSPACES> <LAYER type="image" name="Background" visible="true" id="0"> <DATASET name="background" type="image" workspace="mapper_ws-6" /> </LAYER> </MAP> <OVERVIEWMAP>...</OVERVIEWMAP> <SCALEBAR ... /> </CONFIG> </ARCXML> |
| Using FEATURESERVERWORKSPACE: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT>...</ENVIRONMENT> <MAP> <PROPERTIES>...</PROPERTIES> <WORKSPACES> <FEATURESERVERWORKSPACE name="ifs_ws-7" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" service="states" /> </WORKSPACES> <LAYER type="featureclass" name="States" visible="true" id="1"> <DATASET name="3" type="polygon" workspace="ifs_ws-7" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,255,153" boundarycaptype="round" /> </SIMPLERENDERER> </LAYER> </MAP> <OVERVIEWMAP>...</OVERVIEWMAP> <SCALEBAR ... /> </CONFIG> </ARCXML> |
| Map configuration file used in the Feature Service: |
name="States" visible="true" id="3"> <DATASET name="STATES" type="polygon" workspace="shp_ws-1" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,255,153" boundarycaptype="round" /> </SIMPLERENDERER> </LAYER> |
| Viewer configuration file: |
name="States" visible="true" id="1"> <DATASET name="3" type="polygon" workspace="ifs_ws-7" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,255,153" boundarycaptype="round" /> </SIMPLERENDERER> </LAYER> |
| Default viewer configuration file: |
name="States" visible="true" id="1"> <DATASET name="2" type="polygon" workspace="ifs_ws-7" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,255,153" boundarycaptype="round" /> </SIMPLERENDERER> </LAYER> |
| After layer rendering has been changed in the viewer configuration file: |
name="States" visible="true" id="1"> <DATASET name="2" type="polygon" workspace="ifs_ws-7" /> <VALUEMAPRENDERER lookupfield="POP1999"> <RANGE lower="482025" upper="11351422" label="Less than 11351422"> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,255,0" boundarycaptype="round" /> </RANGE> <RANGE lower="11351422" upper="22220818" label="11351422 - 22220818"> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,170,0" boundarycaptype="round" /> </RANGE> <RANGE lower="22220818" upper="33090215" label="22220818 - 33090215"> <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,85,0" boundarycaptype="round" /> </RANGE> </VALUEMAPRENDERER> </LAYER> |
| Using AVIMSWORKSPACE: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT>...</ENVIRONMENT> <MAP> <PROPERTIES>...</PROPERTIES> <WORKSPACES> <AVIMSWORKSPACE name="av_ws-6" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" view="Roads" map="roads21204240" /> </WORKSPACES> <LAYER type="image" name="Roads" visible="true" id="3"> <DATASET name="mymachine.domain.com:roads21204240:Roads" type="image" workspace="av_ws-6" /> <IMAGEPROPERTIES transparency="0.80" /> </LAYER> </MAP> <OVERVIEWMAP>...</OVERVIEWMAP> <SCALEBAR ... /> </CONFIG> </ARCXML> |
| Using MOIMSWORKSPACE: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT>...</ENVIRONMENT> <MAP> <PROPERTIES>...</PROPERTIES> <WORKSPACES> <MOIMSWORKSPACE name="mo_ws-4" url="http://mymachine.domain.com/scripts/esrimap.dll" service="GPS_Points" /> </WORKSPACES> <LAYER type="image" name="GPS Points" visible="true" id="4"> <DATASET name="mymachine.domain.com:GPS_Points" type="image" workspace="mo_ws-4" /> </LAYER> </MAP> <OVERVIEWMAP>...</OVERVIEWMAP> <SCALEBAR ... /> </CONFIG> </ARCXML> |
| Using OVERVIEWMAP and SCALEBAR: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT>...</ENVIRONMENT> <MAP>...</MAP> <OVERVIEWMAP backgroundcolor="255,255,255" framefillcolor="255,0,0,80" frameoutlinecolor="255,0,0" zoomfactor="4.0"> <LAYERDEF name="Oceans" /> <LAYERDEF name="Countries" /> </OVERVIEWMAP> <SCALEBAR backcolor="212,208,200" fontcolor="0,0,0" mapunits="decimal_degrees" scaleunits="feet" screenunits="inches" /> </CONFIG> </ARCXML> |
| Example default.axl file: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <MAP> <PROPERTIES> <ENVELOPE minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0" name="Initial_Extent" /> <MAPUNITS units="decimal_degrees" /> </PROPERTIES> <WORKSPACES> <IMAGESERVERWORKSPACE name="mapper_ws-6" url="http://mycomputer.domain.com/servlet/com.esri.esrimap.Esrimap" service="background" /> <FEATURESERVERWORKSPACE name="ifs_ws-7" url="http://mycomputer.domain.com/servlet/com.esri.esrimap.Esrimap" service="World" /> </WORKSPACES> <LAYER type="image" name="background" visible="true" id="0"> <DATASET name="background" type="image" workspace="mapper_ws-6" /> </LAYER> <LAYER type="featureclass" name="Countries" visible="true" id="1"> <DATASET name="0" type="polygon" workspace="ifs_ws-7" /> </LAYER> <LAYER type="featureclass" name="United States" visible="true" id="2"> <DATASET name="1" type="polygon" workspace="ifs_ws-7" /> </LAYER> </MAP> <SCALEBAR backcolor="212,208,200" fontcolor="0,0,0" mapunits="decimal_degrees" scaleunits="feet" screenunits="inches" /> </CONFIG> </ARCXML> |
| Using ENVELOPE Initial_Extent: |
| <PROPERTIES> <ENVELOPE minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0" name="Initial_Extent"/> <MAPUNITS units="decimal_degrees" /> <PROPERTIES> |
| Using ENVELOPE Initial_Extent and Extent_Limit: |
| <PROPERTIES> <ENVELOPE minx="-61.1" miny="3.7" maxx="91.7" maxy="61.3" name="Initial_Extent"/> <ENVELOPE minx="-61.1" miny="3.7" maxx="91.7" maxy="61.3" name="Extent_Limit"/> <MAPUNITS units="decimal_degrees" /> <PROPERTIES> |
| Including SCALEBAR: |
| <?xml version="1.0"
encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <MAP>...</MAP> <SCALEBAR backcolor="212,208,200" fontcolor="0,0,0" mapunits="decimal_degrees" scaleunits="feet" screenunits="inches" /> </CONFIG> </ARCXML> |
| Map Config | Viewer Config | Default.axl | |
| Primary purpose | Used as input to ArcIMS services | Saves current map and viewer configuration on the client | Used to load ArcIMS services in an ArcIMS Java Viewer |
| Created by | ArcIMS Author or XML Editor | ArcExplorer 4 or ArcIMS Java Viewers | ArcIMS Designer |
| File is located | On server | On client | On server |
| Data sources | Local network only and must be accessible by ArcIMS Spatial Server | ArcIMS services and local network on client | ArcIMS services only |
| Valid workspaces | SHAPEWORKSPACE, IMAGEWORKSPACE, SDEWORKSPACE | IMAGESERVERWORKSPACE, FEATURESERVERWORKSPACE, AVIMSWORKSPACE, MOIMSWORKSPACE, SHAPEWORKSPACE, IMAGEWORKSPACE, SDEWORKSPACE | IMAGESERVERWORKSPACE, FEATURESERVERWORKSPACE, AVIMSWORKSPACE, MOIMSWORKSPACE |
