| CHANGE_METADATA_ACCESS | Examples |
| <CHANGE_METADATA_ACCESS | Attribute
Description Table |
| docid ="string" private ="true | false" > No Child Elements </CHANGE_METADATA_ACCESS > | |
| Bold: Attribute or child element is
required. | |
| Attribute | Usage | Back to Top |
| docid | 1 String used to uniquely identify a
document. The client used to publish the metadata is responsible for
creating the document ID. This ID is automatically assigned when using
ArcCatalog. If another client is used, GET_UUID can be used to
request a valid ID. The format for an ID is the
following: {HHHHHHHH-HHHH-HHHH-HHHH-HHHHHHHHHHHH} where H is a hexadecimal digit (0-9,a-f,A-F). The ID is limited to 38 characters. | |
| private | 2 Determines whether document is viewable for all users. Use "false" if the document is viewable by all users. Use "true" when the document is viewable only by the document owner. | |
| Example 1: | Back to Top |
| <?xml version="1.0"
encoding="UTF-8" ?> <ARCXML version="1.1"> <REQUEST> <PUBLISH_METADATA> <CHANGE_METADATA_ACCESS docid="{C64D8F38-82B4-11D5-99C2-000086460FA0}" private="true" /> </PUBLISH_METADATA> </REQUEST> </ARCXML> | |
