| CHANGE_OWNER | Examples |
| <CHANGE_OWNER | Attribute
Description Table |
| docid ="string" newowner ="string" > No Child Elements </CHANGE_OWNER > |
| Bold: Attribute or child element is required. | |
| Attribute | Usage | Back to Top |
| docid | String used to uniquely identify a document. The client
used to publish the metadata is responsible for creating the document
ID. This ID is automatically assigned when using ArcCatalog. If another
client is used, GET_UUID can be used to request
a valid ID. The format for an ID is the following: {HHHHHHHH-HHHH-HHHH-HHHH-HHHHHHHHHHHH} where H is a hexadecimal digit (0-9,a-f,A-F). The ID is limited to 38 characters. |
| newowner | New owner name. Must be a value that you already used when logging in. | |
| Example 1: | Back to Top |
| <?xml version="1.0"
encoding="UTF-8" ?> <ARCXML version="1.1"> <REQUEST> <PUBLISH_METADATA> <CHANGE_OWNER docid="{5289D9C3-55BD-4D58-A9DD-24B40427F943}" newowner="publish" /> </PUBLISH_METADATA> </REQUEST> </ARCXML> |
